Expand HTTP Settings when reading file from web
  • January 15, 2025
  • 20 views
virtualcitymatt
Forum|alt.badge.img+39
When reading a file from the web the only options available to configure the client is the Authentication section. In some cases it is needed to tweak some of the client settings in order for requests to properly get though.
Sometimes it would be nice to add custom headers or change the SSL settings for example.
Of course the workaround is to just stick a HTTPCaller followed by a feature reader, however, this also means that you need to deal with temp files etc etc which just adds complexity to the workspace
Best answer by liamfez
Was this meant to be under Ideas?
liamfez
Forum|alt.badge.img+36
  • January 15, 2025
virtualcitymatt
Doh! -yes, here is the idea:
