I have georefferenced pdf file(HLB_Map) and i need a output as digitalized layout map( for reference i have attached ) by using raster pdf file...Please give a guidence
@pradeephj3571 Converting a georeferenced PDF to vector data in FME is doable, but there are a few key decisions that affect how clean your output will be!
RasterSelector → isolate bands if needed
RasterBandInterpreter → convert to grayscale if required
