{workspace} and {repository} email template macros return _undefined_
  • Jan 13, 2017 6:47 PM UTC
  • 5 replies
  • 94 views
jess
I'm attempting to use the following email template with FME Server 2015.1.3.2 :
<fmeblock>
This notification e-mail was generated automatically from FME Server (PROD). Please contact your system administrator or submit a service ticket for support. Do not reply to this e-mail. FME transformation job {id} has FAILED. Workspace: {workspace} Repository: {repository} Status: {StatusMessage} Submitted: {timeRequested} Job Start: {timeStarted} Job End: {timeFinished} Logfile: {logFullPath}
</fmeblock>
{workspace} & {repository} are both returning "_undefined_". All the other macros seem to work fine. Any suggestions?
Best answer by erik_jan
It seems these keywords were not available until FME Server 2016.
See this article: missing keywords
  • Jan 13, 2017 7:22 PM UTC
I suggest to monitor the topic notified and see if the workspace and repository values are in the json notification data.
erik_jan
Forum|alt.badge.img+26
  • Jan 13, 2017 7:24 PM UTC
  • Jan 13, 2017 7:31 PM UTC
I agree.
This is what I can see on a 2015.1.2 Server:
    "ws_topic": "CCD_NOTIFICATION",
    "id": "25436",
    "StatusMessage": "Terminator: Aborting Translation as directed by mapping file. Message is 'Unexpected error!'.",
    "LogFileName": "job_25436.log",
    "timeFinished": "Fri-13-Jan-2017 02:27:35 PM",
    "logHome": "C:/ProgramData/Safe Software/FME Server///Logs",
    "timeRequested": "Fri-13-Jan-2017 02:27:30 PM",
    "StatusNumber": "859017",
    "requestKeyword": "JOB_SUBMITTER_SERVICE",
    "jobsuccess_topic": "CCD_NOTIFICATION",
    "jobfailure_topic": "CCD_NOTIFICATION",
    "timeStarted": "Fri-13-Jan-2017 02:27:30 PM"
geoal
Forum|alt.badge.img+4
  • Nov 27, 2019 3:21 PM UTC
Same Problem on FMESerer 2019.1.2
Hi @virtual,
Sorry that you are running into this issue, since you are in 2019 can you confirm if you are using Automations or still the old method Email Subscriptions?
