Workbench fails when run from Flow Apps - Runs fine with "Run Workspace"
  • December 17, 2024
  • 44 views
sam_appleton
Forum|alt.badge.img+7
When I run a workspace via an App I get the following error:
Microsoft Azure SQL Database Non-Spatial Writer: A suitable Microsoft SQL Server OLE Driver is not found. Install Microsoft OLE DB Driver for SQL Server from http://www.microsoft.com/en-ca/download/details.aspx?id=56730
I can see from earlier on in the logs that it failed to connect :
Microsoft Azure SQL Database Non-Spatial Writer: Failed to connect using Microsoft OLE DB Driver 19 for SQL Server. Provider error ''.
When I run the same workspace from “Run workspace” it connects and runs fine:
Microsoft Azure SQL Database Non-Spatial Writer: Trying to connect using Microsoft OLE DB Driver 19 for SQL Server…
Microsoft Azure SQL Database Non-Spatial Writer: Starting execution of BEGIN_SQL commands
I tried deleting the app and creating it again but that didn’t seem to work.
TIA
Best answer by sam_appleton
Hi ​@virtualcitymatt,
The original server app and dependencies were imported via project file. I manually re-published the workbench and re-created the server app which looks to have solved the issue
virtualcitymatt
Forum|alt.badge.img+34
Could it be somehow related to the database connection?
I wonder if the connection being used is the same by the app as when you run the workspace. For example does the user/token running the app have permission to use the connection deified in FME Server?
What kind of authentication are you using on the database connection?
sam_appleton
  • December 19, 2024
I’m using a database connection and I can see that the server app is trying to reference the same  connection. I can see from the warnings that user/ID/Server might be empty:
Is that what the logs are showing?
sam_appleton
  • December 19, 2024
