system caller running for ever
  • Mar 19, 2022 7:54 AM UTC
  • 152 views
f.kemminje
Forum|alt.badge.img+11
I used rets-connecter runner to download the source data(CSV file) from vendor , and after that fme will read this file for further process. But My System Caller running forever, it's not coming out, executing continuously..
But in command line , it executes immediately and come to the Drive prompt(i mean E:\temp>)
fmw file attached.
Can Anyone pls help
    Command line to run this workspace:
        "E:\Program Files\FME2021\fme.exe" E:\FME_TEMP\wb-xlate-1647675806459_11696
          --FME_LAUNCH_VIEWER_APP "YES"
Starting translation...
Current FME version: FME 2021.2.1.0 (20211203 - Build 21797 - WIN64)
FME_HOME is 'E:\Program Files\FME2021\'
FME Database Edition (node locked-crc)
Serial Number: Z6XB-SJY8-15LX
Permanent License.
Machine host name is: PXLLTPRD276
Locale: en_IN
System Encoding: windows-1252
FME Configuration: FME_BASE is 'no'
FME Configuration: FME_MF_DIR is 'E:\FME_TEMP/'
FME Configuration: FME_MF_NAME is 'wb-xlate-1647675806459_11696'
FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2021.2.1.0'
Operating System: Microsoft Windows 10 64-bit  (Build 19042)
FME Platform: WIN64
System Status: 269.09 GB of disk space available in the FME temporary folder (E:\FME_TEMP\wbrun_1647672465569_11696\fmetmp_1e)
System Status: 31.77 GB of physical memory available
System Status: 100.13 GB of virtual memory available
START - ProcessID: 17496, peak process memory usage: 44472 kB, current process memory usage: 44472 kB
FME Configuration: Command line arguments are `E:\Program Files\FME2021\fme.exe' `E:\FME_TEMP\wb-xlate-1647675806459_11696' `LOG_STANDARDOUT' `YES'
FME Configuration: Connection Storage: 'C:\Users\frq\AppData\Roaming\Safe Software\FME\'
Shared folders for formats are : E:\Program Files\FME2021\datasources;C:\Users\frq\Documents\FME\Formats
Shared folders for transformers are : C:\Users\frq\AppData\Roaming\Safe Software\FME\Packages\21797-win64\transformers;E:\Program Files\FME2021\transformers;C:\Users\frq\AppData\Roaming\Safe Software\FME\FME Store\Transformers
Shared folders for coordinate systems are : C:\Users\frq\Documents\FME\CoordinateSystems
Shared folders for coordinate system exceptions are : C:\Users\frq\Documents\FME\CoordinateSystemExceptions
Shared folders for coordinate system grid overrides are : C:\Users\frq\Documents\FME\CoordinateSystemGridOverrides
Shared folders for CS-MAP transformation exceptions are : C:\Users\frq\Documents\FME\CsmapTransformationExceptions
Shared folders for transformer categories are : C:\Users\frq\Documents\FME\TransformerCategories
FME Configuration: Reader Keyword is `MULTI_READER'
FME Configuration: Writer Keyword is `NULL_DEST'
FME Configuration: Writer Group Definition Keyword is `NULL_DEST_DEF'
FME Configuration: Reader type is `MULTI_READER'
FME Configuration: Writer type is `NULL'
FME Configuration: No destination coordinate system set
FME Configuration: Current working folder is `E:\FME_TEMP'
FME Configuration: Temporary folder is `E:\FME_TEMP\wbrun_1647672465569_11696\fmetmp_1e', set from environment variable `FME_TEMP'
FME Configuration: Cache folder is 'E:\FME_TEMP'
FME Configuration: FME_HOME is `E:\Program Files\FME2021\'
FME Configuration: Start freeing memory when the process exceeds 95.30 GB
FME Configuration: Stop freeing memory when the process is below 71.47 GB
Creating writer for format: NULL (Nothing)
Trying to find a DYNAMIC plugin for writer named `NULL'
Loaded module 'NULL' from file 'E:\Program Files\FME2021\plugins/NULL.dll'
FME API version of module 'NULL' matches current internal version (3.8 20210302)
Creating reader for format:
MULTI_READER(MULTI_READER): Will fail with first member reader failure
Using Multi Reader with keyword `MULTI_READER' to read multiple datasets
Loaded module 'Geometry_func' from file 'E:\Program Files\FME2021\plugins/Geometry_func.dll'
FME API version of module 'Geometry_func' matches current internal version (3.8 20210302)
Loaded module 'InspectorFactory' from file 'E:\Program Files\FME2021\plugins/InspectorFactory.dll'
FME API version of module 'InspectorFactory' matches current internal version (3.8 20210302)
Reading...
Emptying factory pipeline
SystemCaller: Executing `"E:\Program Files\MarketLinx\Rets Connector\RetsConnectorRunner.exe" Sumter_County'
Best answer by richardatsafe
Hi @f.kemminje​ ,
I would put the start command in front of your executable. This should allow the workbench to continue on after running your command  eg.
start "myexecutable.exe" "myfile"
richardatsafe
  • Mar 23, 2022 9:02 PM UTC
Hi @f.kemminje​ ,
f.kemminje
  • Mar 24, 2022 7:08 AM UTC
Thanks, Richard. Very good Answer.
"Like hitting on the head"😀 @richardatsafe​
