Parameter 'DestDataset_ORACLE_NONSPATIAL_7' must be given a value ???
  • Mar 4, 2019 8:57 AM UTC
  • 120 views
Hi all,
I'm getting this statusmessage (Parameter 'DestDataset_ORACLE_NONSPATIAL_7' must be given a value) when running a FME Workbench script as a scheduled FME Server job once a day. Can't figure out, what it means.
The connections are embedded in the FME script. However, when I run it under my own user, or the FME Server admin user, it works fine, so I can't do any error searching or further testing.
Any ideas on how to understand and resoive this problem will be appreciated??
Forget it - problem solved.
  • Aug 4, 2020 6:14 AM UTC
And how do you solved it? I have the same problem.
Thanks
mattwilkie
Forum|alt.badge.img+11
  • Jan 28, 2021 9:00 PM UTC
yeah, same here.
sekarjntu
  • Dec 15, 2021 10:29 AM UTC
Hello could u let us know how did u solve it. i also hav same issue
