MSSQL_SPATIAL writer: Failed to open writer
  • May 5, 2021 3:52 AM UTC
  • 106 views
Hi all,
I've publish my workspace with SQL Server connection to FME Server and build an automation from that. However, the error message "MSSQL_SPATIAL writer: Failed to open writer" is returned when I run the automation.
error
I've check all three workaround given in this article, " https://community.safe.com/s/article/fme-and-sql-server-troubleshooting-guide " but none of them works.
Anyone have any idea or suggestions on how can I resolve this issue?
daraghatsafe
Hi @aafirah​ does the workspace work on FME Desktop before it gets published to Server?
  • May 7, 2021 2:52 AM UTC
Hi @daraghatsafe​.
Yes, the workspace works and successfully update the database in SQL Server. FYI, I'm using the ArcGIS Pro Data Interoperability Workbench application.
