Log file not created for jobs unless admin account is logged in to the web interface
  • Oct 31, 2024 1:00 PM UTC
  • 158 views
markcoopersdc
Hi
We have recenly started using FME Flow more. When someone runs a flow app no log file is created. However, if the admin user logs onto the web interface and they run the app again (on the same or different pc), a log file is created.
Is this expected behaviour? If not, does anyone know how to get round this?
Thanks
Best answer by markcoopersdc
Hi. Turns out it was actually a disk space issue and the log files were being removed almost immediately. It was just a coincidence about the admin user being logged in!!
Forum|alt.badge.img+63
So if I understand you correctly, the admin can see the job that was run through the app in the job history but can’t see the log for it? Unless they’re logged in while the app is running a job?
markcoopersdc
  • Oct 31, 2024 4:17 PM UTC
