Issue with SchemaScanner Misinterpreting ID Field Data Type
jugoslaviaa
I have an ID field that is correctly read by FME as varchar(22) when writing using the Feature Writer.
However, before that, I use the SchemaScanner, and it incorrectly detects the data type as fme_real64. As a result, the original value is eventually written in scientific notation, like 2.2072213393213062e+21, instead of preserving the original string format.
Is there a way to ensure that SchemaScanner correctly detects the field as varchar(22) to prevent this issue? Any suggestions would be appreciated!
nielsgerrits
Forum|alt.badge.img+54
I think adding a space to OBJ_ID as a suffix using an AttributeCreator before the SchemaScanner and remove this space afte the SchemaScanner using an AttributeTrimmer should work. It is hacky and a workaround, but I think it does what you need.
jugoslaviaa
  • March 19, 2025
A space did not work but adding # worked however fme_varchar(23) of course instead fme_varchar(22). Do you know why SchemaScanner messes up  like this?
nielsgerrits
It tries to interpret the data type, but why this results in a scientific notation, I do not know. What data format are you writing to?
As to the char 22 vs char 23, you probably can solve this by inserting a dummy feature with a dummy 22 character string as id in the stream before the SchemaScanner and remove this feature after the SchemaScanner. This is probably more performance efficient as well.
Forum|alt.badge.img+38
  • March 19, 2025
Can you not set the type explicitly in an AttributeManager prior to the schemascanner?
jugoslaviaa
  • March 19, 2025
@ebygomm What do you mean explicitly? When I add AttributeManager, it immediately recognizes varchar(22) and SchemaScanner still think it is fme_real64 although I added AttribiteManager
nicholass
  • April 2, 2025
@jugoslaviaa Did you happen to sort this/ find a workaround? Getting the exact data type for my schema is very important for the validity of my data.
I also have this issue with my attribute data type going from fme_real64 to fme_int16.
jugoslaviaa
  • April 2, 2025
Unfortunately, I could not find a plausible workaround
