How to use results of one fme workbench to feed into Where statement on reader of the next in FME FLow
  • Feb 15, 2024 12:58 PM UTC
  • 127 views
markcoopersdc
Hi
I am creating an automation in FME Flow.
My first workbench looks at a SQL database and extracts the most recent date/time. I would like to use this value to feed in to the Where clause of an Oracle reader in a second workbench so I can extract all records greater than that date/time without having to read all the records in. However, I cannot find anyway to pass the attribute value of the first workspace to the second.
Im sure I read somewhere that this was possible using parameters with workspace runners in Form?
Best answer by geomancer
An alternative is to use FMEFlowJobSubmitter.
But I think you can do it all in the same workspace, when you access the Oracle database with a FeatureReader or an SQLExecuter.
oscard
Forum|alt.badge.img+23
  • Feb 15, 2024 1:13 PM UTC
I believe you need to use an Automation Writer in your first workspace  That writer exposes the values to the next workspace on a Flow Automation.
geomancer
Forum|alt.badge.img+69
  • Feb 15, 2024 1:32 PM UTC
