How to Load User Parameter Choices From a PythonCaller Loop Result
  • Nov 30, 2023 12:28 AM UTC
  • 203 views
fmelearner
Forum|alt.badge.img+3
I have a simple PythonCaller (for now) which basically is something like this
import fme
import fmeobjects
import arcpy
class FeatureProcessor(object):
    def __init__(self):
        """Base constructor for class members."""
        pass
    def input(self, feature):
        geom = ["Point", "Multipoint", "Polyline", "Polygon","Envelope"]
        for geo in geom:
          print(geo)
        self.pyoutput(feature)
    def close(self):
        pass
    def process_group(self):
        pass
Can you please let me know
1- Pass the Result of Python  from PythonCaller to User Parameter Choices
2- How to Pass selected values from here to second PythonCaller2 to only simply print out the selected choice?
I tried to make it as simple as possible and sorry for confusion!
Best answer by david_r
As mentioned by @Takashi Iijima​ , all parameters are read-only once the workspace has started.
To retrieve a user parameter in Python, use the fme.macroValues dictionary, e.g.
import fme
param_value = fme.macroValues.get('USER_PARAM_NAME', 'My default value')
See also this article: https://community.safe.com/s/article/python-and-fme-basics#Parameters
  • Nov 30, 2023 3:58 AM UTC
Hi @bhk​ ,
Unfortunately there is no way to configure a user parameter at run time dynamically, you will have to configure the parameter when you create the workspace.
  • Nov 30, 2023 8:30 AM UTC
import fme
