How to Get the Dropped/Added File Information While Using Directory Watch in Automation
  • Aug 2, 2024 5:02 PM UTC
  • 169 views
fmelearner
Forum|alt.badge.img+3
Using FME Server FME Server 2021.1 (Build 21607 - win64) I have created a Directory Watch automation to send an email if any new file added into the Directory
Which is working as expected but can some one please let me know how I can grab information like File name and SIZE and time and send it to by the email.
lifalin2016
Forum|alt.badge.img+42
  • Aug 6, 2024 9:41 AM UTC
The ‘file action’, ‘file path’ and ‘file root name’ are transferred as part of the success message from the DirectoryWatch (under Directory).
You will however need a small workspace to find and output the file size (if file was added or updated).
Using FME Server 2022.2 myself.
fmelearner
  • Aug 8, 2024 3:46 PM UTC
Hi lifalin2016
Thanks for your comment. Is it possible for you to share some images of your script? how should I output the The ‘file action’, ‘file path’ and ‘file root name’ on any  workspace  like excel sheet?
Thanks
matt.m-at-safe
Forum|alt.badge.img+14
@bhk
Try using a directory and file pathname reader and passing the values back the Automation using an Automation Writer.
Please see image below.
Hope this helps.
lifalin2016
  • Aug 14, 2024 10:55 AM UTC
Shown is a small demo workspace with a single published parameter (e.g. Filename Existing) named FILEPATH. In the automation you pass the Directory/File Path to the workspace parameter:
Then e.g. use a PythonCaller in the workspace to find the file size:
Hope this helps.
Cheers
Lars I
