How to get FME Server Webhook Payload to Workspace in FME Desktop?
  • Oct 25, 2023 9:39 PM UTC
  • 201 views
crstnaiw
I have setup a FME Server Webhook trigger in the automations section and want to put the payload received into a database table by running a workspace after the action is triggered. Please help or advise if this is not the correct way? Thank you #Automation​ #Webhook
Best answer by ctredinnick
There is an article here which may help: https://community.safe.com/s/article/webhooks-and-fme-server
Working backwards, you want your workspace to write the payload to a database, so your workspace needs to get the payload. So you need a text parameter, to pass the payload into your workspace.
Then, in the FME Server automation, you can set the workspace parameter to receive the value of the webhook message content
imageTo test run on desktop, you'll need to get the actual webhook payload. If you don't know what it looks like, you can add a logger to the automation, then trigger the webhook to see what is received by FME Server.
ctredinnick
Forum|alt.badge.img+22
  • Oct 25, 2023 10:27 PM UTC
crstnaiw
  • Oct 26, 2023 4:39 PM UTC
@ctredinnick​ This is perfect! Thank you for your response, I am able to do it now!
