How to define the message in Notification failure by email
  • May 26, 2023 4:46 PM UTC
  • 122 views
arthy
Forum|alt.badge.img+8
Hello,
I would like to set up a notification so that every workspace that failed on FME Server will send an email.
I have set the configuration the Subscriptions
Notification Subscription - FME Serveralong with changes on the file fmeserverconfig.txt
FmeserverConfigHowever, I received an email with
FME transformation job 5237 failed.
while instead I would like to receive something like this json
 {"id": "3", "requestKeyword": "JOB_SUBMITTER_SERVICE",
 "timeFinished": "Mon-15-Aug-2011 02:04:20 PM",
 "timeRequested": "Mon-15-Aug-2011 02:04:20 PM",
 "timeStarted": "Mon-15-Aug-2011 02:04:20 PM",
 "LogFileLocation": "\\Server\FMEServer\Logs\jobsubmitterservice\FME_7D150E1F_1313442260444_4244.log",
 "LogFileName": "jobsubmitterservice\FME_7D150E1F_1313442260444_4244.log",
 "StatusMessage": "A fatal error has occurred. Check the logfile above for details",
 "StatusNumber": "1",
 "urlPrefix": "http://locahost/"
Any ideas?
@rylanatsafe​ , @david_r​ ,  @Takashi Iijima​  and others
keziaatsafe
Hi @arthy​ ,
Please note that this functionality is considered legacy and can be completed using FME Server Automations. Please see Send email from Automations for more information.
The email body is set up in the Subscription, JobSubmitter_Email_JobFailure. JobSubmitter_Email_JobFailure Email BodyAs you can see, the job ID is populated in the email using the attribute {id}. I believe you can grab the other workspace attributes (time start, time finished, etc.) from Automations> Email Action > Email Body > Text Editor. Please try out the attributes with and without "job."
  • {job.id} --> {id}
  • {job.timeFinished} --> {timeFinished}
  • {job.timeStarted} --> {timeStarted}
  • {job.workspace} --> {workspace}
Text Editor
Hope this helps!
Kezia
arthy
  • Jun 5, 2023 2:08 PM UTC
Hi @arthy​ ,
  • {job.id} --> {id}
Text Editor
Hope this helps!
Kezia
@keziaatsafe​
In fact the link https://community.safe.com/s/article/send-email-from-automations is enough when you want to send an email from an automation.
But what I really want to do is to have in place an automation that will (i) detect any workspace that failed on the FME server a s soon as it happened and (ii) send an email to a specific email address.
How should I proceed to achieve this double objective?
