How can I receive JSON that is being posted to a topic on FME server and have it write to an AGOL Feature Service?
  • Mar 28, 2019 4:28 PM UTC
  • 51 views
asellars
Participant
Thanks everyone in advance about helping me sort this out.
I have a topic set up on FME server and have an outside system posting a simple JSON to it. I then have a subscription that is subscribed to that topic with a workspace associated to it.
I can see that it is receiving the JSON in: Resources>System>Temp>Subscriptions
When I published this workspace to the server, I subscribed it to the topic and set: Parameter to Get Topic Message: "Source JSON (JavaScript Object Notation) File or URL. I used the JSON downloaded from the temp folder to create the workspace.
At this point I can see the job starting each time the JSON is posted to the topic, but it is not getting the data to the writer.
Am I missing a parameter that needs to push the JSON from the topic to the reader correctly?
  • Mar 29, 2019 8:40 AM UTC
When publishing the workspace to the server, did you associate your JSON or Text File reader to receive the notification JSON document through the associated published parameter?
