Get info from all unknown addresses from API.
  • Sep 16, 2020 2:20 PM UTC
  • 47 views
I want to get all data in the API, which I do not know what is.
For example, i know that there is one package with information at this address:
https://objektkatalog.geonorge.no/api/package/EAID_A408BF17_3017_41c7_BC37_D6AADDD6634B
But I do not know the EAID for all packages, so I want to get everything from:
I'm currently using the httpCaller. Does someone know how to do this?
Thanks a lot!
  • Sep 16, 2020 2:59 PM UTC
As far as I know there are no standard way of doing this, it seems that the way the objektkatalog is implemented is specific to GeoNorge and you'll have to look around in their API to see if they have some sort of discovery service that lets you list all the available package IDs.
An alternative would be to contact technical support at GeoNorge to see if they can help with the relevant information.
  • Sep 16, 2020 3:06 PM UTC
Try plaing around with this URL, as long as you specify "text=<something>" it returns a CSV containing a list of all the matching objects with their ID, here's an example looking for "FKB", you'll find your example object in the result:
https://objektkatalog.geonorge.no/api/search?text=fkb&navPaths=&limit=5000&mediatype=csv
It doesn't seem to work if text is left blank, you you have to have an idea for what to look.
