FmeServerJobSubmitter http connection on long running job
  • Jul 30, 2019 9:51 AM UTC
  • 85 views
Hello,
If there is a FmeServerJobSubmitter transformer with options:
Wait for Job to Complete = true
Will it keep http connection untill job is done?
itsmatt
Forum|alt.badge.img+48
  • Jul 30, 2019 2:08 PM UTC
Yes I believe it should - Is that what you are experiencing? Or is it failing after a certain amount of time?
  • Jul 31, 2019 1:02 PM UTC
So the connection is between engine and web server or other components (like core?) take part it it as well?
It fails in my case after 5 min and I don't know what may be the case here. Submitted job is still running but submitter fails after that time. I got infromation that i may be because of load balancer but hmm...
itsmatt
  • Jul 31, 2019 1:57 PM UTC
Ah I see you also posted this question: https://knowledge.safe.com/questions/96045/fmeserverjobsubmitter-problems.html
Did you get in touch with support? The core is likely involved. Basically it just makes a HTTP call to the FME Server as I understand it.
You can test out the HTTPCaller with you're own call following this structure: http://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/job_submitter_service.htm
To simulate the 'waiting' you should use the 'opt_servicemode' directive and set it to sync.
You should also be able to just copy the Direct URL from the advanced section when you go to run this job directly from FME Server. I think by default the opt_servicemode is already set to sync. This way you will also get a response
