filecopy object - what is the difference between running manually in FME Server and scheduling the job to run?
  • Oct 4, 2018 2:31 PM UTC
  • 6 replies
  • 105 views
I have a job I have created in FME Desktop 2017.1 which processes a file, and I use a filecopy transformation to move the file to an archive folder once it has been processed.
The job uses two parameters, one for the working folder and one for the archive folder. I have published the job to an FME Server (version 2017). When I run the job manually from the Server from the "Run Workspace" page the job runs correctly. However, when I schedule the job to run automatically it fails at the filecopy transformation, it is treating the file differently.
This is a screenshot of the FME job, showing the two published parameters, and how the filecopy transformation has been configured. The job starts with a Path transformation which is populated from the [INPUT_FILE] parameter.
Below is a screenshot of the job running as scheduled, the errors are shown in red.
Here is the same job running, the only difference being I ran it from the “Run Workspace”.
Any pointers/suggestions are extremely gratefully received, thank you.
  • Oct 4, 2018 2:56 PM UTC
Could you perhaps post a screenshot of the schedule definition, in particular the published parameters used by the FILECOPY writer?
From the scheduled job.
From the resources page
  • Oct 4, 2018 3:15 PM UTC
I notice that you have a space in $(D0036 Files), and I'm wondering if that's fully supported. Would it be possible to create a copy of this resource without the space in the resource name (not the display name, the space should be ok there) and try again?
Thank you, that did the trick.
So no spaces in your FME Server Resources :-)
  • Oct 5, 2018 7:38 AM UTC
Great to hear that it worked. Although it sounds like a small bug, since it works when you run the workspace manually. Please consider reporting this to Safe support, linking back to this thread.
