Extract and copy sub folder
hugues
Hi. I have a folder name PLAN. In the folder PLAN i have a lot of subfolders (B53, B54, B89, etc..). More then 500. In each subfolder (b55 for example) i have a subfolder name TERRITOIRE (PLAN/B54/TERRITOIRE, PLAN/B109/TERRITOIRE), and also other folders with other name. I want copy TERRITOIRE subfolder from each subfolder in a new folder with the name of subfolder.
NEWFOLDER/B56/ TERRITOIRE
NEWFOLDER/B55/TERRITOIRE.
Thank for help.
danilo_fme
Forum|alt.badge.img+49
  • January 17, 2022
Hi @hugues​
Did you try the Writer FileCopy?
Thanks in Advance,
Danilo
  • January 18, 2022
Hi @hugues​ , you can use the Directory and File Pathnames [PATH] reader with these parameter settings to extract all the paths of TERRITOIRE folders under the root folder PLAN.
  • Source Dataset: <PLAN folder path>
  • Path Filter: TERRITOIRE
  • Recurse Into Subfolders: Yes
  • Allowed Path Type: Directory
Rename "path_unix" (full path of 'TERRITOIRE') to "filecopy_source_dataset", then extract subfolder name (e.g. 'B54', 'B109') from the full path with the FilenamePartExtractor (use Folder Name Attribute).
Finally copy the TERRITOIRE folder(s) with the File Copy writer.
  • Destination Dataset <NEWFOLDER folder path>
  • Subfolder Name: <attribute storing subfolder name extracted with FilenamePartExtractor>
  • Copy Source Folder: Yes
