Engine managment , is there any issue with a automation calling workbenches that cannot run on the same engine?
  • Sep 28, 2023 4:00 PM UTC
  • 35 views
j85824
For example I have automation MyAutomation that runs two workbenches, WB1, WB2. WB1 can run on engines 1 - 5(determined by the folder it is in on the FME Server), WB2 can run on engines 3-5. Can an issue arise where WKB1 is running on engine 2 and completes by calling WKB2, that cant run on Engine 2?
hkingsbury
Forum|alt.badge.img+73
  • Sep 28, 2023 7:06 PM UTC
I don't think that will happen as the job routing to queues (and therefore engines) is completely independent of what calls the job
