Downloading and comparing two datasets (from WMS to Shape)
  • Apr 6, 2021 3:03 PM UTC
  • 85 views
claireproemeren
Hello,
I've made a workbench that downloads data to Shape automatically once per month from https://geodata.nationaalgeoregister.nl/hwh/eenheden/wms/v1_0?request=getcapabilities&service=wms (WMS).
This time I would like to make a workbench that compares the geometry and administrative data from the Shape files with each other (January-February, February-March and so on). I am thinking about doing this with the ChangeDetector transformer, but that's where my idea stops.
Could anyone give me advice on this?
Many thanks,
Claire
Forum|alt.badge.img+63
The ChangeDetector is the way to go, you'll have to feed it two datasets (old and new) and based on one or more key attributes and/or geometry it can find the changes. Best advice I can give you really is to just give it a try.
Two parameters to look out for are the Lenient Geometry Matching (whether or not a different vertex order is a change) and Vector Tolerance (to avoid tiny geometry differences due to rounding errors)
caracadrian
Forum|alt.badge.img+23
  • Apr 7, 2021 6:55 PM UTC
The ChageDetector is the transformer you are looking form.
It's easy to set up, has an intuitive Help section.
I would recommend a PathReader, some grouping of you files by month and sending it 2 by 2 to WorkspaceRunner that runs a workspace containing the Readers and ChangeDetector.
But, I recommend using WMF instead of WMS to get your data if you want to compare features geometry.
Rasters are not suited for this comparison.
