Cron expression - what wrong with this one?
  • Sep 19, 2023 2:08 PM UTC
  • 504 views
scarter
Forum|alt.badge.img+10
Hi forum,
I'm very new to FME Flow. I need to set up a schedule using cron expression for 07:00 Monday to Saturday, all year. I've entered...
0 7 * * 1-6
However FME Flow gives a message: "Invalid cron expression: 0 7 * * 1-6"
I cant see what's wrong with it. Any thoughts?
See attached image.
Swk_cronThanks,
Stuart
nielsgerrits
Forum|alt.badge.img+67
Please see https://community.safe.com/s/article/writing-cron-expressions-to-schedule-fme-server-jo
I think it should be
0 0 7 ? * MON-SAT
  • Sep 19, 2023 2:15 PM UTC
Personally, I always end up using this CRON generator, since I end up forgetting the syntax between uses: https://www.freeformatter.com/cron-expression-generator-quartz.html
Which would give you:
0 0 7 ? * MON,TUE,WED,THU,FRI,SAT *
scarter
  • Sep 19, 2023 2:16 PM UTC
0 0 7 ? * MON-SAT
Yes, that worked. Thank you.
scarter
  • Sep 19, 2023 2:36 PM UTC
Most Google guidance I found suggested five fields:
·         minute of the hour (0-59), or leave as *
·         the hour (0-23), or leave as *
·         day of the month (1-31), or leave as *
·         month (1-12), or leave as *
·         day of the week (0-6 where 0 or 7 is Sunday), or leave as *
Thus my effort of 0 7 * * 1-6
I didn’t realise Flow wanted it’s cron expressions to be a bit more expanded that that.
Thanks,
