Can FME connect/read the database files of the 4D system? (extensions like: .4DD, .4DB)
  • Feb 26, 2021 4:00 PM UTC
  • 111 views
zuzanna_sz
Forum|alt.badge.img+4
nielsgerrits
Forum|alt.badge.img+67
I believe FME can't read those. See the Formats Matrix.
You can add it to the Idea list.
zuzanna_sz
  • Feb 28, 2021 11:39 AM UTC
Hi @nielsgerrits​
I know the Format Matrix, thx. I thought that maybe there are some FME users who are also familiar with 4D software and could help with some workarounds here. I will suggest that reader as an idea if I will be force to work with this data more often.
alvisrudzitis
Hello!
Did You try some of SQL readers? Could You give some example DB?​
zuzanna_sz
  • Mar 2, 2021 3:36 PM UTC
Hello!
Unfortunately, I am not able to share the data (client data), but if I will get a "sample" that can be published, I will do so. For now, I found a workaround extracting data from there with SQL queries to MS SQL Server
