Calculating moving average (3 rolling points) in FME.
  • September 20, 2023
  • 167 views
Hello,
I have a dataset with 1000 categories (A, B, ...) (please see the following sample). For each category I want to calculate 3 points moving averages. Table 1I developed the following workbench that using a Tester filter data for each category and then calculating the 3 points moving averages for one category (here port A). However, for each port of the Tester I should repeat all transformers again (transformer after the Tester), which is difficult for 1000 categories. I created a custom transformer but again I should import the custom transformer 1000 times. In the custom transformer I used a Counter which for each port should start counting from zero. But it is added up after that it is applied for each port. I set the Count Space of the Counter on local. But still didn't work. Can someone please let me know a better way to calculate this moving averages without those all repetitions of transformer. FYI, I am using FME 2022.
Best answer by jkh
virtualcitymatt wrote:
You should be able to do this in just an AttributeCreator.
Inside the AttributeCreate you can enable "Adjacent Feature Attributes" which can let you look back a a given number of features.
Here's an example:
Essentially the logic is as follows:
If the category in the current feature matches the previous category and the one 2 behind then calculate the average of the 3 features. If the catagory does not match then do nothing (which leave ave_3 empty)
Hi @virtualcitymatt thank you so much for the answer and for your great explanation about the logic behind the transformer.
virtualcitymatt
Forum|alt.badge.img+39
Here's an example:
nielsgerrits
Forum|alt.badge.img+55
You are looking for Adjacent Feature Attributes in the AttributeCreator. Then you can do it as it is done in Excel. Attached sample workspace demonstrating this.
If
Category = feature[-2].Category
then
@average(@Value(feature[-2].Value),@Value(feature[-1].Value),@Value(Value))
RollingAverage3Sample(2021)_1RollingAverage3Sample(2021)_2RollingAverage3Sample(2021)_3
Here's an example:
If
then
Hi @nielsgerrits thank you so much. This is a great answer.
