Automation 'Run a Workspace' Retry Default Settings
  • May 31, 2023
  • 7 views
vn1
Forum|alt.badge.img+4
Is there a place from the web interface or configuration files where default values can be modified regarding Automated Retries?
Number of attempts
Wait between attempts
Backoff multiplier
Randomization factor
Maximum wait between attempts
sanaeatsafe
Forum|alt.badge.img+7
At this time, the web UI only allows for the Automated Retry settings to be set on individual Run Workspace actions, but not universally. If this is something you'd like to see, I'd encourage you to submit an Idea to the Community for this feature: https://community.safe.com/s/bridea/acideasULT__brIdea__c/00B4Q00000AWlEVUA1
However, there are a number of more general "Job Recovery" settings in the configuration files that may be useful for your workflows: https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Job_Recovery.htm
Hope that helps!
