Automation not triggering via external calls (Survey123, Postman)
  • Jun 12, 2023 4:04 PM UTC
  • 104 views
I have followed the instructions here. Step two doesn't function properly. I have submitted surveys to the webhook url, postman requests, but nothing has triggered the automation, the log is empty.
However, if use an http caller from a workbench, I can trigger the automation.
  • Jun 12, 2023 4:40 PM UTC
Do you get any error messages when testing the webhook from Postman? Can you share some screenshots from your Postman setup?
  • Jun 12, 2023 4:48 PM UTC
This is the error from Postman:
imageError from Survey123 :
Automation:
No results for triggers in the log.
  • Jun 12, 2023 8:18 PM UTC
Automation:
Looks like you'll have to look in the server logs:
http://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/About_Log_Files.htm
In particular the 500 (internal server error) is unexpected. Also make sure this error doesn't come from some server in between, e.g. a proxy sever.
itsmatt
Forum|alt.badge.img+48
  • Jun 13, 2023 7:24 AM UTC
Automation:
Proxy is a good tip: The HTTPCaller has a habit of not using the proxy server. If you want to see if it is going through your proxy server you can turn on debug logging where you can see more information.
