Automation Email Watcher Email Attachments Path
  • Sep 14, 2021 10:19 PM UTC
  • 80 views
Why do I get this error?
2021-9-14 16:52:33 | File Copy Writer: Feature contains an invalid source dataset '$(FME_SHAREDRESOURCE_DATA)EmailAttachments\\20210323145356-FME_Server_Email_Watcher-External_-_LOE_Field_Ticket-ad0dc73d-6839-4747-8e4a-e6160c913495'. No file operations will be performed for this feature.
The specified folder exists. I am unable to put a slash between $(FME_SHAREDRESOURCE_DATA) and EmailAttachments in the automation configuration best I can tell. I have tried using the StringReplacer in the called workspace to put a in a slash and that didn't work. I have attached the workbench, pic of automation, log files for automation and called workspace.
ciarab
Forum|alt.badge.img+10
  • Sep 14, 2021 11:55 PM UTC
When I get this error message on the file copy writer I usually find it's a permissions issue that ​fme server can't access the file .
B​y the looks of the file path I'd imagine it should be accessible but maybe try browsing to that location under resouces within fme server interface and confirm $(FME_SHAREDRESOURCE_DATA)EmailAttachments\\20210323145356-FME_Server_Email_Watcher-External_-_LOE_Field_Ticket-ad0dc73d-6839-4747-8e4a-e6160c913495'
What are you trying to copy, a folder and contents ?
  • Sep 15, 2021 3:29 AM UTC
I want to copy the folder’s contents into another folder.
