FME AR in data inspector >25.1
  • Nov 24, 2025 7:41 AM UTC
  • 110 views
j.botterill
Forum|alt.badge.img+69
I can transform 2D GIS into 3D and write to the FME AR format, branded Realise in Form 25.1
I can’t however “inspect” a .fmear file in the Data Inspector.
Is Safe software planning on returning this functionality ?
itsmatt
Forum|alt.badge.img+48
  • Nov 25, 2025 7:52 AM UTC
The .fmear file is just a zip archive. I think these days the internal 3D format used is gltf, however, at one point I read the was an option to output an obj instead. Im not 100% though.
There are tonnes of tools that will read gltf just not FME yet.
dmitribagh
Forum|alt.badge.img+20
  • Nov 28, 2025 4:55 PM UTC
Hi ​@j.botterill,
As Matt said above, fmear files are zip archives. Since we use them on iOS, they contain USDZ files (representing assets matching feature types) and a sqlite database with metadata, annotation information, anchor, etc.
Since FME does not support USDZ reading, we cannot use out-of-the-box FME for reading fmear files, however, there is a custom transformer I created, USDZReader (https://community.safe.com/fme-hub-alerts-55/usdzreader-34290), which uses Blender integration to bring in USDZ files. All you have to do is to install Blender, and specify the path to its executable in the USDZReader.
Based on this transformer, I created a custom FMEAR reader, but didn’t publish it. All it does is reading both USDZ and SQLite, joins all the summaries to features, reads anchor, and deals with coordinates. I didn’t test it well, but I can share it with you, just let me know.
Dmitri
danilo_fme
Forum|alt.badge.img+58
  • Nov 29, 2025 6:34 PM UTC
Hi ​@j.botterill,
Dmitri
Great explanation ​@dmitribagh
