Writer connection with published parameter not persistent
  • Mar 27, 2019 2:06 PM UTC
  • 0 replies
  • 53 views
I have a set of workspaces that must write either in a production database or in a development database.
So, I use a published parameter for the "connection" parameter which seems to work well.
But despite that it works properly, when I edit the connection parameters, the dialog box shows a database connection from the dropdown list instead of my published parameter.
It's very disturbing because there is always a doubt that I haven't well configured the writer with my published parameter.
And I can't afford to send data to the wrong connection...
Is this a bug of FME or did I miss something ?
I use the same setting for my SQLExecutor and SQLCreator transformers and I have not this problem with these transformers.
The problem occurs only with writers and readers.
I tried with FME 2018.1.2.0 and FME 2018.1.1.2
