write ST_geometry to a Postgis database
  • Jan 28, 2016 5:38 PM UTC
  • 138 views
mapper
Forum|alt.badge.img+7
Is it possible to write ST_Geometry to Postgis database? I don't see any parameters in the Postgis writer that would allow this, so I am wondering if there is any work around?
erik_jan
Forum|alt.badge.img+26
  • Jan 28, 2016 5:46 PM UTC
As I recall the answer is Yes.
But you have to create the table in PostGis (using the ST_geometry type) and then import the table definitions in FME.
bigclyde
  • Nov 27, 2019 9:50 PM UTC
This is exactly what I need to do (migrating a Geomedia Sql Server Warehouse to an Esri enterprise Postgis geodatabase) but I see the post is a few years old.
Is it still true? Is there any other way?
Thanks
