Write files from attributes - Fanout does not do the trick
  • May 11, 2020 7:47 AM UTC
  • 5 replies
  • 97 views
aron
Forum|alt.badge.img+16
I have a dataset where want to write separate files based on multiple attributes. From the example below I would like to write a file with all the Jones, another with all the Smith, a third with all the Farmer and a fourth with any Kim. Fanout does not handle multiple attributes and in this case the StringConcatenator trick wont help, since most of the rows would be contributing to separate files.
Any ideas on how I can achieve this?
A
B
C
D
Jones
Farmer
Kim
Jones
Smith
Jones
Smith
Farmer
Best answer by takashi
Hi @aron, if I understand your requirement correctly, this workflow does the trick.
  • May 11, 2020 8:12 AM UTC
In the case, do you want to create these three files?
  1. Jones-Farmer-Kim
  2. Jones-Smith
  3. Jones-Smith-Farmer
aron
  • May 11, 2020 8:14 AM UTC
  1. Jones-Farmer-Kim
  2. Jones-Smith
No, I want to create these four files: :)
1. Jones (With features from rows 1-3)
2. Smith (With features from rows 2-3)
3. Farmer (With features from rows 1 and 3)
4. Kim (With features from row 1)
  • May 11, 2020 8:25 AM UTC
bwn
Forum|alt.badge.img+26
  • May 11, 2020 8:58 AM UTC
To add to @takashi 's great idea, may achieve faster execution by replacing the Tester with an AttributeFilter, set to Filter "_fanout_attribute" values. The <Unfiltered> Output Port will have the same values as the Tester above.
This is because AttributeFilter builds an Attribute index and also is Bulk Mode Enabled so generally works faster than the equivalent Tester.
  • In my test FME 2018 workspace with 1,000,000 Features with AttributeCopier->Tester. Takes 26 seconds.
  • With the same workspace with AttributeCopier->AttributeFilter. Takes 0.4 seconds!
aron
  • May 11, 2020 1:14 PM UTC
Thanks! Worked like a dream! :)
