Would someone at SAFE be able to show me how to automate an FMW file to start using Python?
  • Dec 19, 2019 1:11 AM UTC
  • 112 views
I would like some quick instruction on how to automate the start of an FMW process. The current FMW uses a series of files that it converts based on date (i.e. the date is in the filename). I need a Python script to be able to load those files into the FMW project once a month and then run the conversion process.
I realize that this would be best done using FME Server...but what I'm trying to do is build a "proof-of-concept" for management here (they will see and understand the pitfalls of automating a desktop process to run indefinitely).
Thank you
Best answer by warrendev
Before my company had FME Server I had setup FME workspaces using Python with Windows task scheduler.
Here are some helpful links to get you started.
Windows Task Scheduler with Python
http://theautomatic.net/2017/10/03/running-python-task-scheduler/
Run an FME Workspace using Python
https://knowledge.safe.com/articles/1158/run-an-fme-workspace-from-python-using-fmeworkspac.html
fmeobjects.FMEWorkspaceRunner
https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_utilities/fmeobjects.FMEWorkspaceRunner.html
Forum|alt.badge.img+63
If you look at the top of the FME log file (after running a worskpace) you'll see the command line that can be used to run that job. Have that fire from a Python script (or a task scheduler) and that's about it.
warrendev
Forum|alt.badge.img+28
  • Dec 19, 2019 3:45 PM UTC
  • Dec 20, 2019 11:51 PM UTC
Excellent answers...thank you very much. I will continue testing and experimenting.
