WorkspaceRunner and comma-separated parameter lists
Hi, can you please have a look at this issue and see if it's a bug that needs fixing?
https://knowledge.safe.com/questions/42262/to-use-comma-in-variable-of-workspacerunner.html
My colleague stumbled into the exact same issue last week. We had to work around it by substituting the comma for something else, then using a StringReplacer in the child workspace to restore the value.
  • April 3, 2017
I was able to reproduce the situation with FME 2017.0.0.1 build 17271. The part beginning from the first comma will be missing when the parameter is passed to the worker workspace.
In FME 2016.1, the parameter field in the WorkspaceRunner preserves the commas, but the translation result was the same as FME 2017. That is, the part beginning from the first comma will not be passed to the worker.
fmelizard
Forum|alt.badge.img+18
  • April 11, 2017
Hi @david_r and @takashi. Thank you for bringing this to my attention. Unfortunately, the WorkspaceRunner not being able to handle commas in parameters of type "Text" is a limitation of the WorkspaceRunner.
From Development:
"Text parameters don’t encode (make value mapping file safe) value where as Multiline Text parameter does. So if the value has characters like comma that needs to survive for the child workspace then the child workspace’s parameter should be configured as Multiline Text."
Please change the Type of the parameter in the child workspace from Text to Text (Multiline), then open the WorkspaceRunner in the parent workspace and re-choose the child workspace. This should fix the problem.
Setting the parameter to Text (Multiline) ensures that it is encoded when passed to the workspace being run, which is called using a command line. This prevents common delimiters from affecting the command line.
  • April 12, 2017
From Development:
Hi @NatalieAtSafe, thanks for the clarification. I found the WorkspaceRunner could pass a string containing commas to the child workspace after the type of the parameter changed to "Text (Multiline)".
  • April 12, 2017
From Development:
In the doc, there is this note about the Text type parameter.
"Note: Any leading or trailing white space is automatically trimmed. To maintain white space, use Text (Multiline)." -- FME Workbench | Creating and Modifying User Parameters
How about adding a comment regarding the limitation about commas here?
  • May 7, 2017
Hi @NatalieAtSafe, using a Text (Multiline) type parameter would be a workaround in most cases, but the parameter value seems not to be decoded when it is referred from a reader (and writer?) parameter.
See this thread: How to pass comma separated values in work space runner
I think there still is a room to improve here.
fmelizard
  • May 12, 2017
Thanks @takashi. I'll look into this after the UC.
Hi @takashi,
I have filed a PR on your behalf to look into and address this issue. My apologies for any inconvenience this may have caused (I have also replied with this comment to this related Q&A;)
