Working with pooling for floating licenses
  • Sep 26, 2019 8:38 AM UTC
  • 7 replies
  • 143 views
francis
Forum|alt.badge.img+16
Hi all,
We are running a license server (v11.15) with 10 floating licenses ESRI Edition.
The number of users using FME Desktop are growing fast, even faster then the budget :-)
Among the users there are different profiles.
So we want to set up a pool of licenses per AD user group.
For example:
- primarly we want to create a pool of floating licenses professional edition that only members of specific Active Directory group can use
- beside that we want to create a pool of floating licenses ESRI edition preserved for members of an other active directory group
Is this possible? If yes, what's the configuration?
Thanks for sharing the knowledge,
Kind regards,
Francis
itay
Forum|alt.badge.img+19
  • Sep 26, 2019 9:40 AM UTC
Hi @fbulco,
If using FlexLM as licensing server, you can use a command line export the licenses usage, read it and see if it contains the information you need to merge with the AD users/groups
francis
  • Sep 26, 2019 10:07 AM UTC
Hi Itay and followers,
At this moment everybody with fme desktop in our domain can access the license server with 10 floating esri licenses. We know the users and we are aware who is using the licenses.
I read the information on https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Restricting_Licenses_to_Users_or_Groups.htm
And one thing is confusing me:
Any licenses reserved for a user are dedicated to that user. Even when that user is not actively using the license, it is unavailable to other users.
So i was still wondering:
If you preserve for example 5 floating license esri edition to an AD group with 10 members. Then I hope that all the members of the AD group can request one of the 5 floating licenses and that the license use is released when they stop working with it. And that the same license are not available for not members of the AD group.
Is this correct?
francis
  • Sep 26, 2019 10:09 AM UTC
Hi @fbulco,
Is this correct?
itay
  • Sep 26, 2019 10:15 AM UTC
Is this correct?
I honestly dont know, dont have much experience with this. Maybe somebody else can help @david_r, @daveatsafe?
  • Sep 26, 2019 10:22 AM UTC
Sounds like a case for Safe, I haven't really needed to play much with those settings.
rahulsharma
Forum|alt.badge.img+12
Hi @fbulco
You can achieve the desired result by creating a options file. You should be able to specific GROUP name in safe.opt file and use either use EXCLUDE or INCLUDE command for the features you want to block/allow.
Unfortunately, there is no way to automatically add ActiveDirectory Group, you have to do that manually. The detailed instructions should be in Flexara License Administration.pdf document included with your floating license server manager.
The user names can be collected from safe.log file usually username@domain.com
  • The option file should be named safe.opt
  • File should be saved in same directory as lmgrd
  • First Line should define GROUP followed by members of group (user names are case sensitive)
  • Finally add INCLUDE INCLUDEALL or EXCLUDE command
NOTE:
The command is as follows
INCLUDE featurename type name
  • featurename - name of the feature being affected
  • type - one of USER, HOST, DISPLAY, GROUP, HOST_GROUP or INTERNET
  • name - name of the user or group to include
You can also use MAX feature to control, how many users can have access with in a Group
MAX 3 feature1 GROUP
MAX 1 feature2 GROUP ALL_GROUPS
helmoet
Forum|alt.badge.img+8
  • Sep 26, 2019 7:25 PM UTC
