wkt: No attributes in inspector and in writer
dollargis
I try to read a csv-file, that contains geometries in wkt as well as attributes and want to convert these in a shapefile.
The first two lines look as follows:
WKT,fid,objectid,y,bt_nummer,flaeche_qm,name_stat_,x,shape_area,shape_len
MultiPolygon(((4469285.3 5337544.1, 4469292.1 5337435.9, 4469311.4 5337437.0))),1,10,5336470.71,12.4,1297528.91423,Münchener Freiheit,4469371.47,,
(note that I have shortened and cut the vertices)
There are two problems arising:
  1. The inspector doesn't show the attributes at all
  2. The shapefile writer (connected directly) gives only empty - but correctly named - columns in the attribute table
What am I missing?
Best answer by jdh
One issue you might find is that if you try and read the csv directly, the multipolygon coordinates are also separated by a comma, and would be become different columns. Putting quotes around it solves that problem.
Otherwise I don't see a real issue, other than ensuring the encoding is correct.
csvwkt.fmwt
erik_jan
Forum|alt.badge.img+18
  • July 11, 2017
A few questions arise:
Did you set the CSV reader to have field names on the first row?
Did you convert (GeometryReplacer) the WKT attribute to a geometry?
Are the Shape attributes exactly the same as the CSV attributes (case sensitive)?
jdh
Forum|alt.badge.img+28
  • July 11, 2017
csvwkt.fmwt
dollargis
  • July 11, 2017
csvwkt.fmwt
@jdh: Thanks for the example code that greatly helped me a big step further. It turned out the missing quotes were causing that error. Now that I have changed my csv-file accordingly, both geometry and attributes get imported.
However - all attributes get imported as strings, in spite of me providing a csvt-file, indicating the correct data types!
As far as my research goes, this is a known problem with the ogr 1.x version library. I have imported my files successfully with ogr2ogr v. 2.x, but unfortunately this is not an option in my current project.
dollargis
  • July 11, 2017
@erik_jan_: I thought I had done those first two points correctly, but it turned out the quotes were missing. Re. the shape attributes: I want to create the shape dynamically - and it turns out that there is still a problem with the data types ahead.
