why does python "close" function wait for the termination of the whole workspace ?
  • Feb 23, 2017 2:54 PM UTC
  • 13 replies
  • 229 views
I made a curious observation... if there are no transformers following a python caller, the "close" function of this python caller won't be called before the whole workspace successfully ran... And this puzzles me !
(I made three distinct/separated workflows in the workspace and noticed that, if the third workflow ended with an error, the writers the first and second workflows were successfull, but the python callers closing functions had never been triggered even if every feature ran through the "input" function )
Is that how FME is supposed to work and why ?
  • Feb 23, 2017 3:00 PM UTC
FME doesn't call the close() method before it has terminated the translation, e.g. at the end of the whole workspace. If the workspace crashes before the end, the close() method doesn't get called.
erik_jan
Forum|alt.badge.img+26
  • Feb 23, 2017 3:02 PM UTC
As @david_r says. And one of the reasons is that the close function needs to be able to access workspace statistics and log file and those are produced last by the workspace.
Forum|alt.badge.img+7
Could you provide us the Workspace? I would like to take a look at how you tested this.
Thanks!
  • Feb 23, 2017 3:38 PM UTC
Thanks!
You can reproduce using something like this and some print statements in the PythonCaller:
With the Terminator enabled the following is called:
__init__()
input()
If you disable the Terminator:
__init__()
input()
input()
close()
  • Feb 23, 2017 3:45 PM UTC
Then how does a python caller in the middle of the translation closes ? I forced mine to properly close by simply adding a logger with no input after the python caller... I observed this waiting only when there was no transformer/logger/etc. following the python caller, when it was a "terminal leaf" of my workflow tree.
  • Feb 23, 2017 3:47 PM UTC
Thanks!
I had mongodb updates in the python callers, the "feature" function was stacking a bunch of write operations in a bulk operation, then the "close" function would execute the bulk. I figured out that even there was nothing sent to mongo even if the python had passed every feature for a while before the error.
  • Feb 23, 2017 3:48 PM UTC
I'm not sure I understand what you mean. Can you give a concrete example, or even better, a sample workspace that demonstrates the issue?
  • Feb 23, 2017 3:54 PM UTC
Well, yes, as you can see the criteria for when FME calles the close() method isn't when there are no more features going through the PythonCaller, but when the entire workspace has ended. This is by design.
Thanks!
Thanks for sharing @david_r
I wasn't aware of this.
  • Feb 23, 2017 4:13 PM UTC
Well, to make it simple, consider the example given by the PythonCaller Documentation
import fmeobjects   class FeatureProcessor(object): 	def __init__(self): 		self.featureList = [] 		self.totalArea = 0.0   	def input(self,feature): 		self.featureList.append(feature) 		self.totalArea += feature.getGeometry().getArea()   	def close(self): 	 	for feature in self.featureList: 	 	feature.setAttribute("total_area", self.totalArea) 	 	self.pyoutput(feature)
How could the following transformer receive its input, considering that self.pyoutput(feature) is in the closing function, if the closing function is waiting for the termination of the translation ?
So I must conclude that the closing function is indeed called right after every featured is processed if and only if there is a transformer following the python caller.
  • Feb 23, 2017 4:15 PM UTC
Oups, that wasn't an answer to your howto comment, I was explaining to jeroenstiers how i noticed this.
  • Feb 23, 2017 4:34 PM UTC
Excellent catch, I was wrong when saying that the close() method gets called when the workspace has terminated, it isn't strictly correct, which you've pointed out. The close() method gets called when there are no more features to process*, which is an important distinction.
From the doc:
The PythonCaller will call two methods on the class: input() and close(). The input() method will be called for each FMEFeature that comes into the input port. When no more FMEFeatures remain, the close() method will be called. Features that need to continue through the workspace for further processing must be explicitly written out using the pyoutput() method.
*) We'd need Safe to give us the definitive answer to exactly what the criteria is, but according to my testing the close() method gets called as soon as FME is certain that no additional feature will ever enter the PythonCaller during that execution. So it might not be at the end of the translation, but it will be guaranteed to be the end of the translation for that particular PythonCaller.
erik_jan
  • Feb 23, 2017 7:37 PM UTC
Sorry, this is true for the Python Shutdown script and not for the PythonCaller.
