where clause Reader Paramaters
  • Feb 7, 2014 12:01 PM UTC
  • 82 views
kalbert
Forum|alt.badge.img+14
Hello,
I have an ESRI Geodatabase Reader using a WHERE clause (Parameters / Advanced / .. that works good.
Now I like to import Feature Types to perform the same query.
Unforunately the Where Clause needs the feature class name in the sub-query:
(ATTR1, ATTRDATE) IN (SELECT ATTR1, MAX(ATTRDATE) FROM SDE.FCNAME GROUP BY ATTR1)
So my question is: is there a way to set the where clause on the Feature Type level instead of the Reader level? Or is there a way to replace the feature class name with a variable/link that points to the appropriate Feature Type?
I appreciate any hint
klaus
sigtill
Forum|alt.badge.img+25
  • Feb 9, 2014 9:20 AM UTC
A workaround might be to use a CREATOR and then a FEATUREREADER on that ESRI GDB. There you can specify the WHERE CLAUSE and have that reader only read that specific reader.
kalbert
  • Feb 10, 2014 10:54 AM UTC
The FeatureReader seems to be a powerfull transformer. But I can't see a way to work with a customized WHERE CLAUSE for every feature type.  Or do I need to use multiple FeaturReaders?
