What is the simplest way of getting the last element in FME list?
  • October 16, 2018
  • 962 views
I am using an attribute creator that is given a List of coordinate. From that list i want the last x value( or the second to last in my example). How do I do it?
In this picture I have tried calculating the number of elements in the list with a list element counter and then i simply write: @Value(_indices_normal{@sub(@Value(_nbr_indices),2)}.x). However this return a sad <missing>.
I haven't been able to find anything in the tutorial: Tutorial: Working with List Attributes or the links provided in it about this specific problem. The closest to an answer that I've found is this lecture slide show: list-manipulation-in-fme.
fmelizard
Forum|alt.badge.img+18
  • October 16, 2018
Hi @hadhafang Use a ListIndexer and set "List Index To Copy" to "@Value(_element_count) - 1" because lists are numbered from 0. But if you just want the last coordinate, instead set the Mode in the CoordinateExtractor to "Specify Coordinate" with a "Coordinate Index" of -1.
  • October 16, 2018
Thank you for a quick answer @DanAtSafe. I had an old coordinate extractor i think. However it doesn't seem to work on my data set but i wrote a pythonCaller that does the same thing.
class FeatureProcessor(object):
    def __init__(self):
        self.featureList = []
    def input(self,feature):
        self.featureList.append(feature)
        xList=feature.getAttribute('_indices_normal{}.x')
        feature.setAttribute('_x2', xList[-1])
        self.pyoutput(feature)
    def close(self):
        pass
  • October 17, 2018
This question seems to be a continuation from the previous one:
"Error: @Coordinate is out of range -- it must be an integer i such that -n = i  n, where n is the number of vertices in the feature".
If the input geometry was a vector such as Line or Polygon, @DanAtSafe's solution would be simplest. That is, you can extract desired coordinates directly by setting "Specify Coordinate" to the Mode parameter and "-1" to the Coordinate Index parameter in the CoordinateExtractor.
However, if the input geometry was a BRepSolid, the setting above could cause the same error reported in the previous question.
As you tried, it would be a workaround to extract all coordinates as a list attribute and then select one, but you need to be aware these points.
  • Since the @sub function returns a floating point number even if the arguments were integers, the resulting value could not be used as a list index directly. You will have to convert the return value to an integer using the @int function, or use the - operator instead of the @sub function.
  • A math operation embedded within a string expression has to be evaluated by the @Evaluate function.
For example, these expressions would return x-coordinate of the last vertex.
@Value(_indices_normal{@Evaluate(@int(@sub(@Value(_nbr_indices),1)))}.x)
@Value(_indices_normal{@Evaluate(@Value(_nbr_indices)-1)}.x)
Alternatively, you can calculate the target index at the first row in the AttriuteCreator, and use it in the following rows, as in:
The ListIndexer could also be used effectively.
