What is causing a difference in attribute handling with the AttributeManager (Arithmetic Editor)?
  • Feb 4, 2020 11:56 AM UTC
  • 80 views
Hello,
I noticed a difference in attribute handling in my FME workbench. I hope anyone can explain what is causing this.
I have the following data:
With the AttributeManager I want to convert the numbers from meters to millimeters (see below).
The outcome of the AttributeManger is:
Why is the bottom value of the first row different than the other two rows?
It is luckily not an obstructing issue in my workbench, because I solved it with the AttributeRounder. But I am curious how this happens, and what the options are to prevent this from happening.
Thanks in advance!
Best answer by redgeographics
It has to do with the underlying mathematic model (I believe that is Tcl), although I am not sure what the exact reason is.
What you can do to avoid it alltogether is wrap the multiplication in an int() function like this:
@int(@Value(bottom)*1000)
Forum|alt.badge.img+63
  • Feb 4, 2020 12:17 PM UTC
Thank you for your quick reply!
