Using Parallele Processing using FME Server
  • Jul 20, 2017 5:37 AM UTC
  • 5 replies
  • 58 views
mygis
Forum|alt.badge.img+14
Hi there,
This is a question of a general nature. I understand that parallel processing is making use of the CPU's cores to process certain grouped data. However, since the FME engines are running/licensed each based on the existing cores in the server's CPU; would the processed workspace consume an additional engine?
Thanks.
Lyes
Best answer by redgeographics
To illustrate what @david_r said:
All done on a FME Clould 2017 Starter instance (2 engines)
Job 752 is without parallel processing, 753 and 754 are run simultaneously with Moderate parallel processing, 755 is run by itself, also with Moderate parallel processing.
The fact I was able to start 754 while 753 was already running indicates it (753) didn't grab that additional engine.
  • Jul 20, 2017 7:52 AM UTC
Parallell processing does not use additional engines, it will only create multiple child processes within each engine thread.
Forum|alt.badge.img+63
mygis
  • Jul 21, 2017 2:06 AM UTC
Thanks for the clarification @david_r
mygis
  • Jul 21, 2017 2:07 AM UTC
Thanks for the confirmation Hans @redgeographics
mygis
  • Jul 21, 2017 2:08 AM UTC
p.s., cool, we can now accept multiple answers !
