Using HTTPCaller with Body
  • Aug 2, 2021 10:06 AM UTC
  • 185 views
nedwaterman
Forum|alt.badge.img+9
HI,
I've not used the HTTPCaller using a POST request and body attribution.
The API call constructed by the developer has been provided like this:
var client = new RestClient("https://sww.smartchartapi.co.uk/api/Authentication/request");
client.Timeout = -1;
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "application/json");
request.AddHeader("Cookie", "ASP.NET_SessionId=xcqkvogm2bp2yxshsgx1ncbg; AspxAutoDetectCookieSupport=1; __AntiXsrfToken=e680dfae824a472088c01d6672ba8471");
var body = @"{
" + "\\n" +
@"  ""username"": ""SWWAPI"",
" + "\\n" +
@"  ""password"": ""***""
" + "\\n" +
request.AddParameter("application/json", body,  ParameterType.RequestBody);
IRestResponse response = client.Execute(request);
Console.WriteLine(response.Content);
I've set up the HTTP caller like this but am getting a bad result. Any ideas what I am doing wrong?
Capture2Capture
Best answer by sigtill
Might use the https://jsonlint.com/ service to try to create a valid Json for your body. For instance it seems it might be:
"username": "SWWAPI",
"password": "***"
sigtill
Forum|alt.badge.img+25
  • Aug 2, 2021 10:15 AM UTC
Try to replace the BODY with one line withouth newlines:
{" + "\\n" + @"  ""username"": ""SWWAPI"", " + "\\n" + @"  ""password"": ""***"" " + "\\n" +@"}
what is the error message?
sigtill
  • Aug 2, 2021 10:18 AM UTC
"password": "***"
nedwaterman
  • Aug 2, 2021 10:21 AM UTC
"password": "***"
I'm getting
HTTP/1.1 400 Bad Request - https://sww.smartchartapi.co.uk/api/Authentication/request
tried the one line for the body but no joy so I'll try constructing some JSON!
nedwaterman
  • Aug 2, 2021 10:28 AM UTC
"password": "***"
Worked" Created valid JSON and passed it using the correct Content type. Thank you!
