User Parameters Feature Types to Read:
jhawks
Forum|alt.badge.img+7
I knew how to do this, now I can't find it. How to publish features types to read, so that they'll be availble in a public fme server workbench?
fmelizard
Forum|alt.badge.img+18
  • August 20, 2013
This is usually found in the reader>advanced>feature types to read.
From there you can right click it and publish.
Hope this helps,
Itay
  • August 21, 2013
You already found "Feature Types to Read" node on the Navigator window.
To the next, try these steps as Itay suggested.
1) Right-click on "Feature Types to Read" to open the short cut menu.
2) Select "Create User Parameter" item in the menu.
  Takashi
fmelizard
  • August 21, 2013
In your image the source dataset (SDE) is published and therefore not green anymore, after publishing the feature types to read it should also change colour and become available when prompting.
Itay
