Update the location of a point in a table from UTMs
  • Aug 29, 2023 8:01 PM UTC
  • 35 views
i_miss_the_chat
Hello,
I need to update the location of a point in an SDE database from UTM's. Is there a way to write an updated location to the Shape* field?
Thank you.
hrvoje
  • Aug 30, 2023 3:27 PM UTC
This might be done by updating "fme_db_operation" attribute value manually to "UPDATE". And then, while writing feature(s), Feature operation has to be setup to fme_db_operation mode. While writing to SDE OBJECTID must be preserved and used as Match Column. Similar to screenshot below. (Full article can be found here: https://community.safe.com/s/article/geodatabase-behaviour-updating-a-file-geodatabase)
