Unstructured data, selecting by row number
  • Jul 26, 2024 2:00 AM UTC
  • 130 views
joneszero
I’m attempting to create attributes from an unstructured html table.
Looks like this…
The table is originally a Word .doc, that I saved as a .html file so I could read it in FME.
For example, I’d like to create an attribute (AttributeCreator) that selects based on row number … eg “Survey Authority” = Col1 row4
or
“End Date” = Col2 row8
This there a way I can do this ?
thanks
jkr_wrk
Forum|alt.badge.img+37
  • Jul 29, 2024 9:02 AM UTC
I guess the data has the attribute names in the uneven rows and the attribute values in the even rows?
You could do something with the adjacent function in the AttributeCreator.
This creates an attribute with the name Survey Title and the value Survey123/10, and Locality with Sydney, Aus.
After this you should remove all uneven features. And then aggregate the remaining 4 features to one feature.
joneszero
  • Jul 30, 2024 12:22 AM UTC
Thank you, @jkr_wrk
Most helpful, I’ll attempt to solve it as you’ve mentioned above.
s.jager
Forum|alt.badge.img+27
  • Jul 30, 2024 10:34 AM UTC
Is it a doc or a docx? If a docx, you can actually unzip it, and directly use the xml inside. Might be a bit easier. In case your zip-utility does not want to do anything with a docx, just rename the extension to .zip...
jkr_wrk
  • Jul 30, 2024 3:33 PM UTC
@s.jager Good idea to point out docx is actualy xml in zip. But it might be pretty complex to find the right objects in the xml. And find the relations.
But it could make everything a lot easier when working with this file on a regular basis.
