Undefined macro `SourceDataset_FILEGDB_3_FILEGDB_3' dereferenced in file `A:\\...\\...\\FME Worksapces\\wb-xlate-1459541027202_6756'
Program Terminating
This error happened to me today for no identifiable reason. If anyone has encountered this issue or has an idea as to why this could happen I encourage you to share your thoughts here.
After this happened two files were created in the folder where I store my work spaces (Not where temp files go).
AND
wb-xlate-145865875395_6136
A peculiar thing happened to one of my readers and it kept "resetting" to not being set (<Not Set>). So you could not open the containing folder or edit the path. It had no options, but the schema and the reader were still in the workspace.
At first I tried rolling back to the very beginning of my work flow history to check if the translation would run when it used to run, but no, I got the same error.
The problem can be fixed by copying over the entire workflow into another work space.
@XiaomengAtSafe
