Unable to interpret Error message
I'm using FME to read, modify and write data to a oracle database. My queries are working fine but the following error is popping up for every SQL query .
ERROR |BADNEWS: An error occurred while fetching from query
OCI_NO_DATA StatusInfo *STFDB_OCIStatement::fetch(STK_UInt32, STK_UInt32 &)(foundation/framework/util/dbwrap/ocistmt.cpp:661) - StatusInfo *STFDB_OCIStatement::fetch(STK_UInt32, STK_UInt32 &)(foundation/framework/util/dbwrap/ocistmt.cpp:661)
What is it complaining about ? instant client or oracle database ?
version details
  • Using FME 2019.2.2.0 version
  • Mac OS X Version
  • Oracle database version is '12.1.0.2.0'
  • instantclient_19_3
Any help on this would be appreciated.
Best answer by david_r
It is not an error, it is an internal message used by the developers at Safe. Normally you should disable all the debug messages, unless you are looking for some specific issue together with Safe support.
  • January 27, 2020
jovitaatsafe
Forum|alt.badge.img+11
adding onto @david_r's answer, we've got an article that goes into some more detail on the BADNEWS function, how to turn off those messages, and when to use them.
