Unable to determine version of Oracle database right after upgrade to FME 2018
  • May 8, 2018 3:03 PM UTC
  • 224 views
dms2
Forum|alt.badge.img+11
I just upgraded form Oracle 2017.1 to Oracle 2018 and now I'm having issues with Oracle database connections.
I get this 'ORA-12638: Credential retrieval failed' error which is solved by changing SQLNET.AUTHENTICATION_SERVICES= (NTS) to SQLNET.AUTHENTICATION_SERVICES= (NONE) in /oracle home/network/admin/sqlnet.ora.
The thing is that after applying that solution when I execute my workspace there's this Warning line in the log:
Unable to determine version of Oracle database. (serverType=`ORACLE8I', serverName=`myServerName', userName=`myUserNAme', password=`***', dbname=`').
It's confusing because warnings are important in our workflow.
Is there anything I can do to make FME know our database version?
Best answer by fmelizard
Hi @dms2 - Thanks for reporting this to us - This has actually been linked to a bug in FME, we are logging something which we shouldn't be. We are working on a fix but the warning can be ignored in this case, really sorry for the inconvenience here. Can you perhaps expand on how the warning is effecting your workflow?
fmelizard
Forum|alt.badge.img+22
  • May 8, 2018 7:25 PM UTC
dms2
  • May 9, 2018 7:03 AM UTC
Some warnings yield a later error in the workflow. So we check for warnings in the log at certain steps in our workflow and make it stop before the error occurs. This helps us to gather the workspace termination cause (the warning text) to send it to the user.
The new scenario makes us deliberately discard this warning in our already complex scripts.
Hope you find a fix to the bug soon.
  • Jun 5, 2018 12:47 PM UTC
I get this warning when connecting to Oracle too. I can run all the above queries successfully as the same user in sqlplus. The first returns no rows and the second returns a null , because we don't have the Spatial option.
Connected to:
Oracle Database 12c Release 12.1.0.1.0 - 64bit Production
SQL> SELECT * FROM V$OPTION WHERE PARAMETER = 'Spatial' AND VALUE = 'TRUE';
no rows selected
SQL> select sdo_version from dual;
SQL> SELECT VERSION FROM V$INSTANCE;
12.1.0.1.0
trentatsafe
Forum|alt.badge.img+7
Hello @dms2,
I’m pleased to let you know that a recent update to FME has resolved this issue.
You will find the update in our latest FME 2018.1 beta:
https://www.safe.com/support/support-resources/fme-downloads/beta/Should you have any feedback regarding the update, please reply to this thread or contact support. Thank you for your patience as we worked to resolve this issue. We appreciate your involvement in helping us make FME even better!Thank you!
