Unable to access new Data Path folder when changing the Default Path.
  • Jan 3, 2018 4:58 PM UTC
  • 66 views
I'm trying to change the default path for the Data Path, but when I do, FME Workbench is telling me that it does not have access to the directory. I'm not sure why it would not have access nor can I find the log file it keeps telling me to look for. Any ideas?
nathanatsafe
Forum|alt.badge.img+9
Hi @jlindahl,
Sorry you're running into this error. Does this occur right when you are changing the path in the settings - or is it rather an error that results from running a workspace with the new path? Would you be able to provide a screenshot of the error and let me know what version of FME you are using?
I haven't seen this before, but some troubleshooting steps to try might be to check that you have access and read/write privileges on the folder, and that you're using the full path if it is a mapped network drive. Eg. \\\\Server1\\data instead of F:\\data.
Hope this helps,
Nathan
  • Jan 4, 2018 5:01 PM UTC
We were able to fix the issue by reinstalling FME Workbench.
