trying to speed up output of 350+ large size GeoTIFFs
  • Jun 26, 2019 3:54 PM UTC
  • 70 views
clindsey
Forum|alt.badge.img+3
I am attempting to write out 386 geotiffs and each is over 1.5 Gbs in size. It's taking about 15mins to write out each file. I am using parallel processing however when looking at task manager it seems that only 1 CPU is running / writing at a time. I'm looking for some authoring critique or insight as to what i can do to speed up the process. The workflow is attached as well as a screenshot of task manager
sigtill
Forum|alt.badge.img+25
  • Oct 23, 2019 12:19 PM UTC
Hi @clindsey
1. Use a FeatureWriter instead of the Writer - this will make FME start to write the file at once instead of keeping all data in memory
2. Use the WorkspaceRunner on each file: https://www.safe.com/transformers/workspace-runner/
