Translate JSON return to table form
  • Jun 3, 2024 1:04 PM UTC
  • 158 views
waterbeemds
Forum|alt.badge.img+9
I have a JSON return form a HTTPCaller with schema info. An example of the return looks like this:
  "name": "Administration",
  "properties" : {
    "Id" : {
      "type" : "number",
      "required" : true,
      "description" : "The given Id for the object"
    "GeoType" : {
      "type" : "string",
      "required" : true,
      "description" : "The type of object"
The json continues here with more schema info.
I want to turn the information into a table like this:
I have 82 other JSON returns with the same layout but other “name” values and exposing them all takes to much time. I have tried to use JSON transfromers but so far no succes.
Is there a more dynamic solution to transforming the return to my desired solution?
Thanks in advance,
Sander
Best answer by geomancer
This works (after adding curly closing brackets to the given input):
Also see the attached workspace.
andrewj74
Forum|alt.badge.img+8
  • Jun 3, 2024 1:14 PM UTC
See this one here that should help:
can you expose the attributes using the attribute exposer > cached features? or do you want it to be dynamic? if you want it to be dynamic you could use the schema scanner and set up a dynamic writer.
geomancer
Forum|alt.badge.img+71
  • Jun 3, 2024 1:47 PM UTC
waterbeemds
  • Jun 3, 2024 2:07 PM UTC
Hi andrewj74 and geomancer,
Thank you for your responses. Geomancer's solution worked for me and will set it as Best Answer.
I also managed to make a solution using the AttributeExploder after the first JSONFragmenter.
But it uses more transformers in the long run and Geomancer's solution is more in line with the format.
Thanks,
Sander
